Upper transverse bracing http://www-.luthiersforum.com/forum/viewtopic.php?f=10128&t=47614 |
Author: | bcombs510 [ Mon Apr 11, 2016 11:17 am ] |
Post subject: | Upper transverse bracing |
Hello, I'm building a tenor uke, the first one from scratch for me. I've built a couple of the SM uke kits. I searched here and it seems about 50 / 50 in favor or radius the top or flat. I put a 30' radius on the rims and glued the waist and fan braces on after radiused to 30'. I glued them up in a radius dish / go bar just like I use on guitar. Question: When building a guitar I've put the upper transverse brace on flat to try to avoid a gap at the fretboard extension. Do the same for the Uke? It seems like it would be the same, but I'm curious if others do the same? Thanks! Brad |
Author: | Quine [ Mon Apr 11, 2016 12:08 pm ] |
Post subject: | Re: Upper transverse bracing |
I use an upper transverse brace on my ukes. I make it the same size as the lower transverse |
Author: | bcombs510 [ Mon Apr 11, 2016 12:30 pm ] |
Quine wrote: I use an upper transverse brace on my ukes. I make it the same size as the lower transverse Does that mean radiused the same as well? ![]() |
Author: | Alain Lambert [ Mon Apr 11, 2016 5:10 pm ] |
I radius mine to 30 ft also. The Uke is so small you can barely see the radius, I do not remember any problem fitting the neck/FB. May be a little sanding to get the area under the FB flat. Assuming you extend the FB to the sound hole. |
Author: | bcombs510 [ Tue Apr 12, 2016 1:07 pm ] |
Thanks. I went ahead and glued it on flat for this one, let's see how it goes. ![]() Thanks! Brad |
